OcUK Staff
- 23 Feb 2015
- Overclockers UK HQ
Hi guys,
The Corsair Lapdog is available to pre-order now. I've also set up some bundles with all the compatible Corsair K70 Keyboards for a discounted price. You can find the links below.
Ideal for gamers who use their TV's to game, they should be with us the first week of June. There will be limited stock in the UK (I think we are one of only 3 retailers who will have it for launch), so if you fancy one whack a pre-order on and it will be despatched the day we receive our supply.
Corsair Gaming LAPDOG Gaming Control Center @ £109.99 inc VAT
LAPDOG is an ultimate gaming control center which revolutionizes PC gaming in the living room. Designed
specifically to work with award-winning Corsair K65 or K70 series mechanical keyboards and a wired USB mouse. Its large and integrated 11 x 11” performance mouse pad guarantees unrestrained control and precision for your mouse movements. LAPDOG is very comfortable on your lap thanks to underside memory foam cushion that is removable, when needed. LAPDOG also features a built-in powered USB 3.0 hub with additional ports for any USB headset, game controllers, flash drives and supports USB fast-charging. It’s wired for performance to give uncompromised specs and always full, unlimited power.
*Keyboard and Mouse not included
- Designed to work with Corsair K70/K65 series keyboards
- Large 11” x 11” mouse mat area
- Removable memory foam lap cushion
- Built-in powered 4-port USB 3.0 hub
- Additional ports for USB headset and game controllers
- Durable aluminum surface
- Dedicated cable compartment
- Support for USB fast-charging
Contents
- Corsair Gaming LAPDOG Gaming Control Center
- Detachable memory foam lap cushion
- 12V AC charger
- 16ft (5m) connection cable
- Quick start guide
Only £109.99 inc VAT.
ORDER NOW
Corsair Lapdog with Corsair K70 Keyboard (various models)
ORDER NOW
Contents
- 12V AC charger
- Quick start guide
ORDER NOW
ORDER NOW
Clearly there's a market for transformers that also double up as PC cases.
