Might be worth popping the question in cuisine, the food buffs are always eager to recommend their fav toys
I have a Rothenberger one like this,
http://www.plumbcenter.co.uk/produc...azing-torch/?gclid=CLKiyevW98wCFQWfGwod2b8GyQ
Then MAPP cylinders. That's basically the best option/package.
Kitchen ones are generally febal and expensive . Just get a blow torch.
Yeah but "bloeto4ch" nareows it down to about 500 ttpes styles and fuels![]()
I'm going to have to get your renamed to Glaucus if you continue to type like that
If you want something cheap just get the cheapest butane torch you can from somewhere like B&Q. If you want to go crazy and get something really awesome then get a Searzall.
.fair enough i wasnt too sure if there was something specific to aim for cookery wise.But they're all much of a muchness, just go to store and pick one. Only a few choices, nozzle size, ignition system or no ignition system. What canister size is easy and cheap to get hold of in your local store.
And that's hardly a bad post for me.
Edit - misread what you said.
Thought you meant rename me,
