**** The Official Samsung Galaxy S7/Edge Thread ****
Anyone got any recommendations for noise-cancelling headphones for the S7 Edge? I've upgraded from an Xperia Z2 which had great stock headphones that would noise-cancel as soon as they were plugged in and I quite liked the sound too. Plugging them into the S7 and the noise-cancelling is gone and it sounds bloody terrible.
Any recommendations - noise cancelling is key as I work in a chatty office. Thanks.
Well you don't need noise cancelling just buy in ear headphones that naturally cancel out noise.
Press the volume buttons, then on the toast click the down arrow and adjust the notifications volume. Same as before.
I don't seem to have one... Top line changes ringer but not notification, next is mediamedia, then alarm, last one is a finger which is presumably touch sounds? None of them seem to change the notification sound anyway.
What car holder do you guys recommend?
Brodit mount+holder, hands down. :) You buy it specifically to fit your car, and if you swap phone you just buy another holder (no need to disconnect the mount fitted to your car).
I ordered item number 512866 ("Brodit Samsung Galaxy S7 Edge Brodit Active holder with cig-plug "). (This is for the Edge, btw).
Considering trading my S7 Edge for a 6s plus..
Not sure yet but I find myself wanting to head to IoS
This sort of self punishment can cause serious, long lasting harm and needs to stop mate. Please, please ask your gp to see a therapist.
