EVGA 1080 GTX Glitching problem
11 Mar 2016
Just got my new 1080 EVGA FE this morning
only in windows i get glitching when doing anything in games it's fine.
Did a clean install of the latest driver this morning from nvidia, i have also uninstalled and re-installed, same issue.
Monitor is a Dell S2716DG @ 144hz. Before swapping out my Windforce 980Ti's SLI didnt have this issue.
Card at idle is 32c
Version: 368.25 WHQL
Release Date: 2016.5.26
Operating System: Windows 10 64-bit
Language: English (UK)
File Size: 351.43 M
do i need to RMA?
https://www.youtube.com/watch?v=r_UhpKke9Y4&feature=youtu.be
https://www.youtube.com/watch?v=KXpQpwGtl48
Card at idle is 32c
File Size: 351.43 M
do i need to RMA?
I would DDU it completely. Ensure stock clocks. Latest driver, possibly roll it back to prev driver.
Re-seat it aswell. Any jumping around in afterburner etc?
What sort of voltage and core speed is it defaulting too during idle?
If its fine in games its most likely a windows issue.
i haven't even loaded any OC tools on it yet.
just re-seated, uninstalled all nvidia drivers/apps, back to minimum.
just seeing if fixed :rolleyes:
thats a EASY fix
thats a connection is i used to get that on my 4K setup its either a not very good cable or bad connection reseat both ends of the DP/dvi etc
