Cutting/drilling/tapping in Acrylic and metal
29 Dec 2014
The "North"
Hi, this will be my first time case modding so I'm looking for any advice in undertaking this task so I'll get straight to the point.
When cutting acrylic can I use a compound mitre saw for the larger cuts?
What is the best way to drill into metal and then tap the hole?
What is the best way to drill into acrylic and then tap the hole?
How would I go about pass through ports in acrylic/metal?
For more intricate cuts would a dremmel cut through acrylic?
As always any help on this is greatly appreciated and please go as in depth as you can as I am in the dark on this stuff :D
Working with acrylic sheet
DO
Keep masking on as long as possible.
Use metal cutting saw blades and drills which are ground for acrylic sheet.
Make sure all tools are sharp.
Use water or drilling oil as a coolant when cutting sheets over 1/8" thick or drilling sheets over 3/16" thick.
Wet the material before cleaning.
DON'T
Use saw blades with side-set teeth. Saw teeth ideally should be ground with 0 degrees of rake and be of uniform height and shape.
Cutting Acrylic Sheet
Cutting with a knife or scriber
Acrylic sheet up to 3/16" thick may be cut by a method similar to that used to cut glass. Use a scribing knife, a metal scriber, an awl, or a utility knife to score the sheet. Draw the scriber several times (7 or 8 times for a 3/16" sheet) along a straight edge held firmly in place. Then clamp the sheet or hold it rigidly under a straight edge with the scribe mark hanging just over the edge of a table. Apply a sharp downward pressure to break the sheet along the scribe line. Scrape the edges to smooth any sharp corners. This method is not recommended for long breaks or thick material.
Cutting with power saws
Special blades are available to cut acrylic. Otherwise use blades designed to cut aluminum or copper. Teeth should be fine, of the same height, evenly spaced, with little or no set.
Table and circular saws
Use hollow ground high speed blades with no set and at least 5 teeth per inch. Carbide tipped blades with a triple chip tooth will give the smoothest cuts. Set the blade height about 1/8" above the height of the material. This will reduce edge chipping.
When using a hand held circular saw, clamp the sheet to the work surface and use a length of 1x3 wood to distribute the clamping pressure and act as a guide for the saw.
Feed the work slowly and smoothly. Lubricate the blade with soap or beeswax to minimize gumming from the masking adhesive. Be sure the saw is up to full speed before beginning the cut. Water cooling the blade is suggested for thicknesses over 1/4", especially if edge cementing will be performed.
Saber saws
Use metal or plastic cutting blades. The blades you use to cut acrylic should never be used for any other material. Cut at high speed and be sure the saw is at full speed before beginning the cut.
Hand saws
Good results are possible, but very difficult. Be sure the acrylic is clamped to prevent flexing. Flexing at the cut may cause cracking.
Routers and shapers
Use single fluted bits for inside circle routing and double fluted bits for edge routing. At the high speeds at which routers operate it is critical to avoid all vibration. Even small vibrations can cause crazing and fractures during routing.
Drilling
For best results, use drill bits designed specifically for acrylic.
Regular twist drills can be used, but need modification to keep the blade from grabbing and fracturing the plastic. Modify the bit by grinding small flats onto both cutting edges, so the bit cuts with a scraping action. If the drill is correctly sharpened and operated at the correct speed, two continuous spiral ribbons will emerge from the hole.
DO
DON'T
Saber saws
Hand saws
Routers and shapers
Drilling
Thanks for the advice, what would be the route to go down with sanding and smoothing down edges. Is sandpaper best or would I be better with a file/belt sander?
wet and dry used wet, start with coarse work down to fine, finish with an auto type rubbing/buffing compound
you'll get some residue / gloopy stuff on the face of the acrylic while doing it, wash this off, dont wipe it off or it will get scratched
Excellent stuff, I'll have a crack at cutting the acrylic when it arrives then. Is there anything else I should be aware of as the acrylic I'm using is matte/frosted (I wanted a scratch resistant material) :)
