- 7 Sep 2012
- Lancashire, England
I fancy changing my case (currently a Raijintek Agos) and have pretty much narrowed it down to these options:
Phanteks Eclipse P400
Phanteks Enthoo Pro-M
NZXT Source 340
Corsair Carbide 400C
I intend on adding a couple of 140mm front intake fans to whichever case I get as my Zotac GTX 980 Ti AMP! is starting to get a bit toasty with the recent warm weather! Which in turn also affects the CPU temp too
I really like the look of the Eclipse P400 and the NZXT S340, but I feel the front panel might be a bit too restrictive for the the air intake fans. They only have a small gap/opening on the top and bottom of the front panels. Does anyone own one of these cases? What is the airflow like?
Which would you guys recommend? I'm not fussed about having a 5.25" optical bay.
Cheers
NZXT Source 340
Cheers
