I've got an iron gate that needs rehanging. It's currently just screwed directly to the brick wall but I think it might be better off attached to a wooden batten, or post, which is itself attached to the wall.
Questions are;
1 - what is the best way of attaching the wooden post to the wall?
2 - which is the best way of attaching the gate to the post?
So in the drwaing below, do I use some sort of anchor for the post or will plugs and screws be ok and should the gate screws go through to the wall as per the bottom hinge:
Ta
Questions are;
Ta
