He got things wrong all the time.
but he had half a clue about cars and didn't just buy a fleet of Ferraris because he could.
If, for the sake of convenience, we say the wing is a meter wide and 10cm deep (it'll be wider that anyway) then that gives the wing an area of 1000cm^2. At just over 1kg per square centimeter there is about 1 metric ton of air sitting on top of the wing, even if the car isn't moving.
Ignoring that air is compressible for the sake of convenience, and given the density of air is 1.2 kg/m^3, a tonne (1000 kg) of air would yield a volume of 1000/1.2 = 833 m^3.
That's almost a cubic kilometre of air.
To picture a cube of air with a volume of 833 m^3, let's take the cube root. The cube root of 833 m^3 is around 9.4 m. So each side of that imaginary cube of air has length of 9.4 m.
So do you think (almost) a cubic kilometre of air is acting down on the wing?
I reckon all he's done is taken the force acting on the wing and divided it it by 9.91 m/s^2 to give an equivalent mass, which he says is a tonne (since force is analogous to but not the same as mass * acceleration [where in this case acceleration is due to mavity at 9.81 m/s^2]).
But then how would he know the force acting on the wing?
My conclusion? He's talking ********.
They always make silly errors like that. Back when Hammond was riding a Pinarello (that's a bicycle, car fans) in Moscow or wherever it was he claimed it weighed 700g... Erm, no, maybe the frame does, but I can guarantee the whole thing weighs more than that.
Also a ton of downforce at (its top speed) 170mph would be popping rear tires I'd imagine, no way is that wing producing that much alone.
http://media.fcanorthamerica.com/newsrelease.do?id=16546&mid=New ACR Extreme Aero Package delivers nearly 1 ton of peak downforce at top speed through massive adjustable dual-element carbon fiber rear wing, rear carbon fiber diffuser, unique SRT hood with removable louvers, detachable extension for the front splitter and additional dive planes
... at 177 mph top speed...
Downforce on the wings comes from the pressure difference between the top and bottom of the wing.But then how would he know the force acting on the wing?
1000lbs
Not 1000kg
('Merica)
Also that's over the entire body, not just the rear wing.
Biggest aerodynamics going on to produce that is the ground effect
The way to determine downforce with certainty is to perform the area weighted integral of the dynamic pressure (sum of all pressures such as static pressure, shear stress, frictional pressure drop etc) on the wing, and then determine the normal components to the wing, which will give you the magnitude and direction of downforce.
What you said is wrong. The pressure difference is caused by lift/downforce. It's a misconception to say the pressure difference causes lift/downforce (much how people say lift in an aeroplane is caused by fast and slow moving air over the airfoil - however it is true, fast and slow moving air do pass over the airfoil). People try to rationalise this by quoting Bernoulli. The solution is far more complex than this, requiring an understanding of the Euler and Navier Stokes equations.
I'm sure Chris Evans didn't compute the surface integrals. Which is why I said he's talking ********.
Imperial ton = 2000lbs
If you don't mind me asking, how does lift cause the pressure difference?
