Yep, any 10 bullets doesn't have to be consecutive
i want to try CS, but think i might be a bit squishy.
worth trying with randoms? will be on for a bit after 4
Lucky you, I have 0 240 predator's pieces so far ha ha. Might need to get my bleed resistance up, which is currently 0 I think. To be fair we encountered such a group lady weekend and they were weak. We killed them what, three times? Being well build with the set is a must I'd say.
What level do alt characters have to be to store all kinds of stash in them?
Yes,they are not great (i can even say kinda weak),they need to pick 1 player,if a group works well,Preds not going to work,it wasnt that hard to kill them,problem is we didnt worked as are group like first time when we killed them quite easily.
Anyways - im going to try to get that set while working on my current one.
Lvl 4,when you get to Manhattan and claim BoO
Will be back on later, need a 240 strikers holster with three stats if I can.
Nice, I can stash gear sets and 204 weapons on them as well? And the stash is shared right?
Apparently they will be increasing the stash size at some point. Hopefully sooner rather than later...
theyre looking in to it but due to it requiring extra server storage and bandwidth it may not be a quick thing.
I'm on now if you need help.
Edit - Also I'm thinking for Missions that I should carry 2pc Strikers and when doing DZ I should switch it to Final Measure. It kind of makes sense to do that, so I'll be hunting DZ in the evening for striker gear. atm I need normal currency so I can sell the stuff from CS as I need 800K for one recalibration![]()
