EVGA 1080 Hydro Copper
11 Mar 2016
When can we expect to see this released?
From another thread......
Hi guys
I will do my best before I hit the sack in Taiwan.
Roughly here is how I see first stocks hitting the UK.
SC - 9th/10th June
FTW - 16th/17th June.
Classified - End of June
Hybrid/Hydro Copper - Early July.
I am afraid I can only be vague at this stage but we are doing all we can. There is more Founders Edition on the way already in strong numbers and will land during this week. Please do not take these dates as gospel but I hope a decent guide for you.
Thanks
Ben
Looks good, aesthetically. Is the base card unique or the same as one of the other models?
Will it be in anyway sensibly priced, though? I always think these look convenient but it's usually so much cheaper to do it yourself.
EK blocks are with UK stockists already. If you've never put one on before, trust me a drunk sloth could do it. You're actually more likely to **** it up if you get complacent.
Cheaper and dead easier, however unless its an EVGA board or perhaps the odd other manufacturer, you void the warranty.
Built first custom water loop PC last December, and been using GTX680 whilst waiting for Pascal, so this is going to be a huge upgrade for me, along with superwide monitor.
Newbie Q. I have EKWB CPU block, acetal + nickel. I understand you can't mix metal types in a loop? Will the EVGA Hydro go ok into my loop? Thanks!
And I hope this soon lands, my ability to hold on is diminishing by the day!
