I received a birthday present a few days ago, a new steam iron. Exciting stuff I know.
I was recommended to put ironing water in to stop calcium/limescale build up, particularly as my tap water is hard. So I thought I'd give it a whirl.
I almost bought a 1 litre bottle of Comfort ironing water but instead bought a larger bottle of deionised water.
I then read this:
You might think that distilled water would be best for use in a steam iron as all of the impurities and minerals have been removed. However, most steam iron manufacturers now recommend not using only distilled water as it can cause the iron to spit and leak, but instead use a 50/50 mix with normal tap water.
So my question is, do I mix 50/50 or shall I just go ahead and use the deionised water only? Using 50% tap water almost defeats the purpose of keeping it calcium free.
I then read this:
