- 18 May 2010
- London
Wonder if someone with more experience can cast their eye on the following error log.
Recently reinstalled the WSUS as it was broke and non functional.
It's up and running now. And the clients are indeed checking in.
However the majority of them show up with the ! symbol and the message "This computer has not yet contacted".
I've patched the WSUS with this update which I found through a Google search on this issue.
However I dont think it has solved the problem.
When I run: wuauclt /detectnow form a client machine and then view the C:\Windows\WindowsUpdate.log I get the following messages:
2016-06-02 12:18:05:521 296 146c AU AU received policy change subscription event
2016-06-02 12:19:02:796 296 106c AU Triggering AU detection through DetectNow API
2016-06-02 12:19:02:796 296 106c AU Triggering Online detection (non-interactive)
2016-06-02 12:19:02:796 296 146c AU #############
2016-06-02 12:19:02:796 296 146c AU ## START ## AU: Search for updates
2016-06-02 12:19:02:811 296 146c AU <<## SUBMITTED ## AU: Search for updates [CallId = {4FCB0B73-CCD8-4144-8103-809DD91D29B3}]
2016-06-02 12:19:02:811 296 be0 Agent *************
2016-06-02 12:19:02:811 296 be0 Agent ** START ** Agent: Finding updates [CallerId = AutomaticUpdates]
2016-06-02 12:19:02:811 296 be0 Agent * Online = Yes; Ignore download priority = No
2016-06-02 12:19:02:811 296 be0 Agent * Criteria = "IsInstalled=0 and DeploymentAction='Installation' or IsPresent=1 and DeploymentAction='Uninstallation' or IsInstalled=1 and DeploymentAction='Installation' and RebootRequired=1 or IsInstalled=0 and DeploymentAction='Uninstallation' and RebootRequired=1"
2016-06-02 12:19:02:811 296 be0 Agent * ServiceID = {3DA21691-E39D-4DA6-8A4B-B43877BCB1B7} Managed
2016-06-02 12:19:02:811 296 be0 Agent * Search Scope = {Machine}
2016-06-02 12:19:02:982 296 be0 Setup Checking for agent SelfUpdate
2016-06-02 12:19:02:982 296 be0 Setup Client version: Core: 7.6.7600.256 Aux: 7.6.7600.256
2016-06-02 12:19:10:235 296 be0 Misc Validating signature for C:\Windows\SoftwareDistribution\SelfUpdate\wuident.cab:
2016-06-02 12:19:10:250 296 be0 Misc Microsoft signed: Yes
2016-06-02 12:19:10:312 296 be0 Misc Validating signature for C:\Windows\SoftwareDistribution\SelfUpdate\wsus3setup.cab:
2016-06-02 12:19:10:343 296 be0 Misc Microsoft signed: Yes
2016-06-02 12:19:10:359 296 be0 Misc Validating signature for C:\Windows\SoftwareDistribution\SelfUpdate\wsus3setup.cab:
2016-06-02 12:19:10:359 296 be0 Misc Microsoft signed: Yes
2016-06-02 12:19:10:468 296 be0 Setup Determining whether a new setup handler needs to be downloaded
2016-06-02 12:19:10:468 296 be0 Setup SelfUpdate handler is not found. It will be downloaded
2016-06-02 12:19:10:468 296 be0 Setup Evaluating applicability of setup package "WUClient-SelfUpdate-ActiveX~31bf3856ad364e35~amd64~~7.6.7600.256"
2016-06-02 12:19:11:710 296 be0 Setup Setup package "WUClient-SelfUpdate-ActiveX~31bf3856ad364e35~amd64~~7.6.7600.256" is already installed.
2016-06-02 12:19:11:710 296 be0 Setup Evaluating applicability of setup package "WUClient-SelfUpdate-Aux-TopLevel~31bf3856ad364e35~amd64~~7.6.7600.256"
2016-06-02 12:19:11:741 296 be0 Setup Setup package "WUClient-SelfUpdate-Aux-TopLevel~31bf3856ad364e35~amd64~~7.6.7600.256" is already installed.
2016-06-02 12:19:11:741 296 be0 Setup Evaluating applicability of setup package "WUClient-SelfUpdate-Core-TopLevel~31bf3856ad364e35~amd64~~7.6.7600.256"
2016-06-02 12:19:11:772 296 be0 Setup Setup package "WUClient-SelfUpdate-Core-TopLevel~31bf3856ad364e35~amd64~~7.6.7600.256" is already installed.
2016-06-02 12:19:11:772 296 be0 Setup SelfUpdate check completed. SelfUpdate is NOT required.
2016-06-02 12:19:13:838 296 be0 PT +++++++++++ PT: Synchronizing server updates +++++++++++
2016-06-02 12:19:13:838 296 be0 PT + ServiceId = {3DA21691-E39D-4DA6-8A4B-B43877BCB1B7}, Server URL = http://wsus.office.companyname.com/ClientWebService/client.asmx
2016-06-02 12:19:14:102 296 be0 PT WARNING: Cached cookie has expired or new PID is available
2016-06-02 12:19:14:102 296 be0 PT Initializing simple targeting cookie, clientId = b5455598-5ed9-43bc-9865-f80a88194cfd, target group = Desktops, DNS name = wg-0007.office.companyname.com
2016-06-02 12:19:14:102 296 be0 PT Server URL = http://wsus.office.companyname.com/SimpleAuthWebService/SimpleAuth.asmx
2016-06-02 12:19:14:288 296 be0 PT WARNING: GetCookie failure, error = 0x8024400D, soap client error = 7, soap error code = 300, HTTP status code = 200
2016-06-02 12:19:14:288 296 be0 PT WARNING: SOAP Fault: 0x00012c
2016-06-02 12:19:14:288 296 be0 PT WARNING: faultstring:Fault occurred
2016-06-02 12:19:14:288 296 be0 PT WARNING: ErrorCode:ConfigChanged(2)
2016-06-02 12:19:14:288 296 be0 PT WARNING: Message
null)
2016-06-02 12:19:14:288 296 be0 PT WARNING: Method:"http://www.microsoft.com/SoftwareDistribution/Server/ClientWebService/GetCookie"
2016-06-02 12:19:14:288 296 be0 PT WARNING: ID:f8f080a8-1324-415c-b18a-6b5d22a19699
2016-06-02 12:19:14:319 296 be0 PT WARNING: Cached cookie has expired or new PID is available
2016-06-02 12:19:14:319 296 be0 PT Initializing simple targeting cookie, clientId = b5455598-5ed9-43bc-9865-f80a88194cfd, target group = Desktops, DNS name = wg-0007.office.companyname.com
2016-06-02 12:19:14:319 296 be0 PT Server URL = http://wsus.office.companyname.com/SimpleAuthWebService/SimpleAuth.asmx
2016-06-02 12:20:26:938 296 be0 PT WARNING: Exceeded max server round trips: 0x80244010
2016-06-02 12:20:26:938 296 be0 PT WARNING: Sync of Updates: 0x80244010
2016-06-02 12:20:26:938 296 be0 PT WARNING: SyncServerUpdatesInternal failed: 0x80244010
2016-06-02 12:20:26:938 296 be0 Agent * WARNING: Failed to synchronize, error = 0x80244010
2016-06-02 12:20:27:094 296 be0 Agent * WARNING: Exit code = 0x80244010
2016-06-02 12:20:27:094 296 be0 Agent *********
2016-06-02 12:20:27:094 296 be0 Agent ** END ** Agent: Finding updates [CallerId = AutomaticUpdates]
2016-06-02 12:20:27:094 296 be0 Agent *************
2016-06-02 12:20:27:094 296 be0 Agent WARNING: WU client failed Searching for update with error 0x80244010
2016-06-02 12:20:27:140 296 10c AU >>## RESUMED ## AU: Search for updates [CallId = {4FCB0B73-CCD8-4144-8103-809DD91D29B3}]
2016-06-02 12:20:27:140 296 10c AU # WARNING: Search callback failed, result = 0x80244010
2016-06-02 12:20:27:140 296 10c AU # WARNING: Failed to find updates with error code 80244010
2016-06-02 12:20:27:140 296 10c AU #########
2016-06-02 12:20:27:140 296 10c AU ## END ## AU: Search for updates [CallId = {4FCB0B73-CCD8-4144-8103-809DD91D29B3}]
2016-06-02 12:20:27:140 296 10c AU #############
2016-06-02 12:20:27:140 296 10c AU Successfully wrote event for AU health state:0
2016-06-02 12:20:27:140 296 10c AU AU setting next detection timeout to 2016-06-02 16:20:27
2016-06-02 12:20:32:079 296 be0 Report REPORT EVENT: {4EA6F424-A36F-41AC-AFD9-6127DF6EFD09} 2016-06-02 12:20:27:094+0100 1 148 101 {00000000-0000-0000-0000-000000000000} 0 80244010 AutomaticUpdates Failure Software Synchronization Windows Update Client failed to detect with error 0x80244010.
2016-06-02 12:20:32:110 296 be0 Report CWERReporter::HandleEvents - WER report upload completed with status 0x8
2016-06-02 12:20:32:110 296 be0 Report WER Report sent: 7.6.7600.256 0x80244010 00000000-0000-0000-0000-000000000000 Scan 101 Managed
2016-06-02 12:20:32:110 296 be0 Report CWERReporter finishing event handling. (00000000)
null)2016-06-02 12:19:14:288 296 be0 PT WARNING: Method:"http://www.microsoft.com/SoftwareDistribution/Server/ClientWebService/GetCookie"
