Nicenot fitted it yet? Come on!
only 2 more to go and then I can attempt to fit the qs
got a set of progressive springs and new fork oil in the shed as well but I've got no plans to do that for a while as I'll need a few days where I don't need the bike just in case and as it's my only transport those times are rare.Still got the front braided line to fit that I've been getting round to since Christmasgot a set of progressive springs and new fork oil in the shed as well but I've got no plans to do that for a while as I'll need a few days where I don't need the bike just in case and as it's my only transport those times are rare.
I have bought a new double banjo with a bleeder nipple in from HEL the other day as well to make bleeding a bit easier.
I don't mind giving anything a go to be honest it's just finding the time and dry weather as I've not got a garage.
Yep I have. Bought a new double banjo with a bleeder nipple in from HEL the other day as well to make bleeding a bit easier.
I plan on doing the seals as well, the dust seals are starting to look a little cracked and worn so the oil seals are probably getting on a bit as well. I've got an abba stand with the front lift kit as well so I should be able to do it without too much hassle when I finally get round to it.
Just the shifter. Mine moves side to side a little as well. Pretty sure it's normal due to the ball joints used to connect the shift lever and shift arm to the shift rod.
On my k5 the shift lever just slides over a rod and then there's a washer and a circlip keeping it on so it's been designed to have some movement in it as there's no way to tighten it, I take it yours is one of the models where it actually bolts between the peg and the rear set?
