Dear All,
Very curious problem here that I can't seem to figure out. I'd like to think I'm relatively IT-literate but this one has me absolutely stumped!
Background / System set up:
I'm currently running an i7 5630X, 16Gb DDR4, Corsair HX1000i and a Radeon 295X2 on an ASUS Rampage V Motherboard. Since I built it last year, it's been running consistently well, games are more than playable and I've been getting around 5.5k on FireStrike Ultra which seems about right for this set-up.
Problem:
Now, I moved my PC yesterday to a different location, and when I went to play FC4 (usual 80fps+) it was unplayable at about 15-20fps which I thought was very odd. I did a quick benchmark on 3dmark and I scored 1,700 - which is nearly 4,000 lower than my previous score...
Now, here's the problem...why would this be the case? I have tried the following things to no avail:
re-install latest drivers
re-seat the graphics card
check CF is enabled on MB
check CF is enabled in CCC
stress test to check temps (all ok)
turn off UPLS
The way it "feels" and the only way I can describe it is it never seems to get to full power...or that CF isn't truly enabled. If you take a look at the image below, GPU jumps to 100% then drops immediately...
So - any suggestions or comments at all would be greatly appreciated!
Kind regards,
Andy
Problem:
turn off UPLS
Kind regards,
Andy
