Hey guys
Two years ago I asked for help with a workstation build and you all helped me a lot, and that machine (with some minor issues) has been working excellently. Now it's time to add a second FP64 optimized machine as our business has grown.
So here are my chosen parts:
My basket at Overclockers UK:
Total: £6,154.40
(includes shipping: £12.60)
Some points:
All thoughts and comments welcome! Thanks a lot.
- 1 x Asus Z10PE-D8 WS Intel X99 (Socket 2011) DDR4 EEB Dual Socket Workstation Motherboard= £449.99
- 2 x Intel Xeon E5-2630 v3 2.4GHz 8-Core with Hyperthreading (Socket 2011-3) - Retail= £619.99
- 4 x Kingston Fury Black 32GB (2x16GB) DDR4 PC4-17000C14 2133MHz Dual Channel Kit - Black (HX421C14FBK2/3= £89.99
- 1 x AMD FirePro W9100 Professional Graphics Card - 16GB GDDR5 - 2816 Shaders= £2,499.00
- 1 x Corsair HX1200i 1200W '80 Plus Platinum' Digital Modular Power Supply (CP-9020070-UK)= £204.95
- 1 x Samsung 950 Pro 256GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive= £143.99
- 4 x Samsung 1.0TB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E1T0B/EU)= £269.99
- 2 x be quiet! Pure Rock Cpu Cooler - 120mm= £26.99
- 1 x Silverstone Raven 4 SST-RV04B-W USB 3.0 Raven Big-Tower - black (SST-RV04B-W USB 3.0)= £109.99
Total: £6,154.40
Some points:
- I need a 10Gbps network card. I think it will be around £200. Nothing in OcUK. ASUS should freaking just put one on these motherboards.
- M2 SSD for OS/software. SATA ones will be on RAID0 for workspace.
- I need a good RAID card as well. I guess it also will be around £200-250, nothing in OcUK.
- PSU is a little overkill, but might add another GPU down the road so better play it safe. Also doesn't hurt to have some headroom given this will be working almost 24/7.
- No watercooling this time. This one will be shoved into a server room. Noise isn't an issue.
- Didn't choose a fancy for CPU cooler, just something that gets the job done well. These CPUs are 85w.
- I wanted to keep it under £6000 but it doesn't so without major sacrifices. Ideas on cutting a little from the price?
