Hello everyone, i am new to the Overclockers UK Forum.
I am an Old Computer addict from the Commodore and Speccy days.
I think my first computer was Steam Powered or maybe it was coal : )
Can i give you the Spec of my current machine, is it worth upgrading components or is the Mobo too old ? I want to play FO4 with everything set on MAX.
Original machine bought was
Mesh Extreme QX G80
Spec now is...
Cooler Master Aluminium ATX Midi Tower
Asus P5 N32- E Sli 680i Mobo
Intel Core Duo Extreme QX6700 Quad Core 2.66, 8mb, 1066 Processor
OCZ 1000 PXS power supply
Vapour X HD 6770 GDDR5 1mb GPU
Asus Xonar DS Sound card
2048mb DDR2 900mhz memory (Kingston) x 4 8mb total
Kingston SV300S37a12 SSD
WD 3 TB Green H/D
Broadcom 802.11g card
Windows 10
HP 2310 Wide LCD Monitor.
I would like to run FO4 at max settings, so update some components or replace Mobo, processor,memory and GPU ?
Have a budget of about £750
Thanks
Mesh Extreme QX G80
Spec now is...
WD 3 TB Green H/D
Windows 10
Thanks
