The ROG Rampage V Edition 10 Owners Thread
Man of Honour
9 Jan 2007
Metropolis
The new Rampage takes performance to another level but of course, it doesn't stop there. New Aura RGB lighting has been added, including on the PCIe slots and an extra 4-pin RGB-strip header to allow lighting effects to go beyond the motherboard itself. The new SafeSlot PCIe is reinforced to prevent graphics cards from sagging and/or breaking the slot.
Having 40 PCIe 3.0 lanes will work wonders if you have the desire to load up every port and slot. We challange you to fill up the four PCIe X16 slots, a PCIe X4 slot, a PCIe X1 slot, NVMe U.2 port and M.2 slot, a whopping ten SATA ports, four USB 3.1 ports (two Type-A & two reversible Type-C), eight USB 3.0 ports and six USB 2.0 ports. For that you'd need a pretty darn big EATX case!
High-end performance can be expected in every aspect of the board. SupremeFX Hi-FI DAC (Digital to Analog Converter), dual op-amps and headphone amp all controlled by Sonic Radar II audio software to make sure you can hear everything you need to hear in the highest quality possible. Dual Intel Gigabit LAN, 3x3 802.11ac Wi-Fi and GameFirst IV have you covered in terms of network speed and flexibility.
The Specs
ROG RAMPAGE V EDITION 10
CPU
Intel® Socket 2011-v3 Core™ i7 X-Series Processors
Supports Intel® 14 nm CPU
Supports Intel® Turbo Boost Technology 3.0
* Refer to www.asus.com for CPU support list
Chipset
Intel® X99
Memory
8 x DIMM, Max. 128GB, DDR4 3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133(O.C.) MHz Non-ECC, Un-buffered Memory
Quad Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists).
Multi-GPU Support
Supports NVIDIA® 4-Way SLI™ Technology *1
Supports NVIDIA® 3-Way SLI™ Technology
Supports NVIDIA® 2-Way SLI™ Technology
Supports AMD 4-Way CrossFireX Technology *1
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX Technology
Expansion Slots
4 x PCIe 3.0/2.0 x16 (x16, x16/x16, x16/x8/x8, x16/x8/x8/x8 or x8/x8/x8/x8 mode with 40-LANE CPU; x16, x16/x8 or x8/x8/x8 mode with 28-LANE CPU) *2
1 x PCIe 2.0 x4 *3
1 x PCIe 2.0 x1
Storage
New Intel® Core™ i7 X-Series Processors :
1 x M.2 Socket 3, with M Key, type 2260/2280/22110 storage devices support ( Supports PCIE SSDs only)*4
1 x U.2 port, support PCIe 3.0 x4 NVM Express storage*4
Intel® X99 chipset :
10 x SATA 6Gb/s port(s),
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology*5
LAN
Intel® I218V, 1 x Gigabit LAN Controller(s)
Intel® I211-AT, 1 x Gigabit LAN Controller(s)
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Anti-surge LANGuard
ROG GameFirst Technology
Wireless Data Network
Wi-Fi 802.11 a/b/g/n/ac
Supports dual band frequency 2.4/5 GHz
Support ASUS Wi-Fi Go! Utility
Up to 1300Mbps transfer speed
Bluetooth
Bluetooth V4.0
Audio
ROG SupremeFX 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- DTS Connect
- Optical S/PDIF out port(s) at back panel
- Audio amplifier: Provides the highest-quality sound for headphone and speakers
- Premium Japanese-made audio capacitors: Provide warm, natural and immersive sound with exceptional clarity and fidelity
- Sonic Studio II
- Sonic Radar II
USB Ports
Intel® X99 chipset : *3
4 x USB 3.0 port(s) (4 at mid-board)
Intel® X99 chipset : *6
6 x USB 2.0 port(s) (2 at back panel, black, 4 at mid-board)
ASMedia® USB 3.1 controller :
2 x USB 3.1 port(s) (2 at back panel, black, Type-C)
ASMedia® USB 3.1 controller : *3
2 x USB 3.1 port(s) (2 at back panel, red, Type-A)
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (4 at back panel, blue)
ROG Exclusive Features
1 x DRAM channel switch
ROG RAMCache
ROG Aura
- Aura Lighting Control
- Aura RGB Strip Headers
Extreme Engine Digi+ :
- IR3555 PoweIRstage®
- MicroFine Alloy Chokes
- 10K Black Metallic Capacitors
ROG Extreme OC kit :
- ReTry button
- Safe Boot button
- Start button
- Reset button
- Slow Mode
- LN2 Mode
- PCIe x16 Lane Switch
ProbeIt
KeyBot II
- One-click Overclocking
- X.M.P.
- DirectKey
- ClrCMOS
- Power On
UEFI BIOS features :
- O.C. Profile
- GPU.DIMM Post
- Tweakers' Paradise
- ROG SSD Secure Erase
- Graphic Card Information Preview
ROG RAMDisk
Extreme Tweaker
Special Features
5-Way Optimization by Dual Intelligent Processors 5
- 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo Core App
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: Cloud GO!, Remote Desktop, Remote Keyboard & Mouse, File Transfer
ASUS Exclusive Features :
- MemOK!
- AI Suite 3
- Ai Charger+
- Anti-Surge
- USB 3.1 Boost
Remote Entertainment
- Media Streamer
- HyStream
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 4
ASUS EZ DIY :
- ASUS CrashFree BIOS
- ASUS EZ Flash 3
- ASUS USB BIOS Flashback
- ASUS UEFI BIOS EZ Mode
- Multi-language BIOS
- Push Notice
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-DIMM
- ASUS Q-Connector
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Turbo App
Operating System Support
Windows® 10 , 64bit
Windows® 8.1 , 32bit/64bit
Windows® 7 , 32bit/64bit
Back I/O Ports
1 x PS/2 keyboard/mouse combo port(s)
2 x LAN (RJ45) port(s)
2 x USB 3.1 (black)Type-C
2 x USB 3.1 (red)Type-A
4 x USB 3.0 (blue)
2 x USB 2.0 (one port can be switched to USB BIOS Flashback)
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Clear CMOS button(s)
3 x Wi-Fi antenna port(s)
1 x USB BIOS Flashback Button(s)
Internal I/O Ports
1 x Aura RGB Strip Header
2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x M.2 Socket 3 for M Key, type 2260/2280/22110 storage devices support ( Support PCIE SSD only)
1 x TPM header
10 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
3 x Chassis Fan connector(s)
1 x Power Fan connector(s)
1 x Thunderbolt header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x SLI/CFX switch (2/3-WAY adjustments)
1 x Front panel audio connector(s) (AAFP)
1 x MemOK! button(s)
1 x Slow Mode switch(es)
9 x ProbeIt Measurement Points
1 x Thermal sensor connector(s)
1 x EZ Plug connector(s) (4-pin Molex power connector)
1 x Power-on button(s)
1 x Reset button(s)
1 x BIOS Switch button(s)
1 x 5-pin EXT_FAN(Extension Fan) connector
1 x Water Pump header (4-pin)
1 x LN2 Mode jumper(s)
1 x ROG extension (ROG_EXT) header(s)
1 x Safe Boot button
1 x ReTry button
1 x U.2 connector
1 x System panel connector
1 x PCIe x16 lane switch
Accessories
User's manual
SupremeFX Hi-Fi Kit:
- 1 x SupremeFX Hi-Fi
- 1 x SupremeFX Hi-Fi cable
1 x 2-Way SLI bridge(s)
10 x SATA power cable
1 x M.2 Screw Package
2 x CPU installation tool
1 x ASUS 3T3R dual band Wi-Fi moving antennas (Wi-Fi 802.11a/b/g/n/ac compliant)
1 x Fan Extension Card (3 x 4-pin fan out)
1 x Fan Extension card screw pack
1 x 3-Way SLI bridge(s)
1 x 4-Way SLI bridge(s)
1 x Q-connector(s) (1 in 1)
1 x 12 in 1 ROG Cable Label(s)
ROG Fan Label
1 x 5-pin to 5-pin cable
1 x Extension Cable for RGB strips (80 cm)
3 x Thermistor cable(s)
1 x USB drive with utilities and drivers
1 x I/O frame
2 x ROG coasters
BIOS
128 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.0, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information.
Manageability
WfM 2.0, WOL by PME, PXE
Form Factor
Extended ATX Form Factor
12 inch x 10.7 inch ( 30.5 cm x 27.2 cm )
Note
*1 28-LANE CPUs can only support up to 3-Way SLI™/ 3-Way CrossFireX™
*2 The PCIEx8_4 slot shares bandwidth with M.2 and U.2.
*3 The PCIEx4_1 slot shares bandwidth with front USB3_34 ports and back USB3.1_EC1_EA2 ports. If a X2 device is connected to the PCIEx4_1 slot, the front USB3_34 ports will be disabled. If a X4 or higher device is connected to the PCIEx4_1 slot, both front USB3_34 and back USB3.1_EC1_EA2 ports will be disabled.
*4 These ports share bandwidth with PCIEx8_4 slot.
*5 These functions will work depending on the CPU installed.
*6 2 x USB2.0 port at mid-board shares with ROG extension (ROG_EXT) port.
SUPREMEFX HI-FI
SupremeFX Hi-Fi
Hardware:
- 1 x ESS ES9018K2M SABRE DAC
- 2 x LM4562 Op amps
- 1 x TPA6120A2 Headphone amp
- 1 x Cirrus Logic CS5361
- 5 x RC4580 Op amps
Headphone Output Performance:
- Supported formats: Up to 32-bit/384kHz*
- Output (32Ohms): 4.8VRMS (720mW RMS per channel)
- Output (600Ohms): 6.8VRMS (77mW RMS per channel)
- THD+N @ 1K (-3dB): -104dB (<0.0007%)
- Signal to Noise Ratio (A-weighted): -121.1dB
- Crosstalk: -98dB
Rear I/O Ports:
- POWER : 1 x 6-pin PCIe power connector
- SIGNAL : 1 x USB 2.0 header
Front I/O Ports:
- 1 x Volume control knob
- 1 x 6.3mm headphone jack**
- 1 x 3.5mm headphone jack**
- 1 x 3.5mm mic/line in jack
Dimensions:
- 5.25" ODD drive bay Form Factor (14.5 x 4.2x 14cm [W x H x D])***
Note
*Sample rates greater than 32-bit/96kHz
**Only one of these jacks will be active at a given time
***The face of this device is designed to be flush with a standard drive bay with the knob extending 1cm
•Specifications and features vary by model, and all images are illustrative. Please refer specification pages for full details.
•*Precise specifications and features vary by model . Please refer to the specification page
•The product (electrical , electronic equipment, Mercury-containing button cell battery) should not be placed in municipal waste. Check local regulations for disposal of electronic products.
•Products certified by the Federal Communications Commission and Industry Canada will be distributed in the United States and Canada. Please visit the ASUS USA and ASUS Canada websites for information about locally available products.
•All specifications are subject to change without notice. Please check with your supplier for exact offers. Products may not be available in all markets.
•PCB color and bundled software versions are subject to change without notice.
•Brand and product names mentioned are trademarks of their respective companies.
Press Release
ASUS Overview
BUY
Nice thread and I look forward to posting some pics here.
I have a couple of copper coloured cards that should look good on the board.:)
US site still showing a release date of the 17th but nothing elsewhere. I hope we don't have to wait very long.
Im torn between this and the MSI X99 titanium. I'm still using my Asus Rampage 2 Extreme X58 mobo. Its been a rock solid setup from day one. However I do like the white/silver finish of the MSI.
That Titanium looks really nice, very unique and something different for a change... won't be to everyone's taste, but black PCB on Rampage V is like every other board, nothing special, which personally I would want for such an expensive product. I thought they would do something to stand out a bit, but even the RGB isn't anything amazing. The Sabertooth looks more special than this, but the Titanium is something else altogether, and it will be cheaper than the Rampage V also. Definitely would be my choice between the two.
This is a very solid board. Training memory better than the previous version with slightly better efficiency and ofcourse an even more extensive feature set, I have been testing it on Broadwell E for a couple of months now and its the best around. I use it in both OrionX and Supernova too says it all really!!
Until ofcourse Edition8 arrives ;)
Looks great, and will no doubt be a solid performer. Having a SLI setup and a Noctua heatsink, I can barely see my board so all that LED McGubbins would be wasted on me.
I'd definitely buy one of these if I didn't already own a RVE.
Thanks for the reply. Yes I was even considering getting the Sabretooth a while back but held out for the refresh boards. I'm probably going to hold fire for now and wait for some pics here and some online reviews/vids for both boards. :)
I'm second in the queue and I would expect you to get yours in the first batch. Are you getting a new CPU/RAM?
6950X and 16gb Corsair Dominator Platinum 3200mhz.
I was going to try the 3400mhz memory but after reading reviews I don't think the 6950X IMC is up to it.
I like the full speed M.2 even if populating the pci lanes. Just saw the price though eek! I'll have to stick with my X99 Sabertooth.
