- 22 Jun 2015
- South of the north but north of the south.
Hi Guys, was hoping you could give me a bit of tech support!
I'm experiencing a very odd issue with my PC where the raid keeps on failing. I'm currently running 2x 500GB SSD's in raid 0 on an Maximus VI Extreme using the motherboards intel raid controller. Basically when I boot the PC it comes up with a message on the raid saying it's failed I reboot the PC then all is hunky dory and it boots to windows.
Things I have tried to fix it:
Reinstall Windows 10
Delete and Rebuild Raid
Reset CMOS and change battery
Reset BIOS
Re Flash BIOS
Rebuild raid as raid 1 (Still fails but just says degraded)
I'm now at the point where I'm slowly running out of ideas and patience, so any advice would be massively appreciated. Oh also from time to time when I shut the PC down windows will shutdown but the PC stays on and I have to hold the power button in. Only happens once in a blue moon though.
Thanks
Sam
Reset BIOS
Re Flash BIOS
Thanks
Sam
