45 million creds leak from popular .com forums
1 May 2003
Some 45 million logins for 939 popular sites including motorcycle.com, autoguide.com, and mothering.com have been stolen.
The method of attack and actor responsible is unknown, although many of the sites ran a vastly outdated and hackable versions of vBulletin.
Usernames, email addresses, IP information, and passwords are breached.
"Most of the records (over 40 million) were just MD5 with salting and this is insufficient."
Popular passwords included the regular shockers, along with a scattering of seemingly randomised strong codes. The second most popular password was '18atcskd2w' used by 91,103 accounts, with '3rjs1la7qe' coming in fourth spot used by 74,806 accounts.
More information can be found here - https://www.leakedsource.com/blog/verticalscope
The mind boggles how owners of these sites can use such weak hashes and not patch system vulnerabilities :rolleyes: :(
I'm sure OcUK don't make these huge mistakes ;)
That's pretty weird. Sounds like a lot of people are using a 'random' password generator that's not very random...
That's a little odd - why would those random character strings be reused so frequently?
Password generator being used by a lot of people maybe and stored in some sort of password manager?
edit: beaten :(
They probably manually patch the security updates to vB which they probably feel is easier to do than actually update it. :rolleyes:
This is why I use random passwords now and allow Firefox to save them. None of my passwords are the same, are as long as possible and contain symbols if they are allowed.
Some sites don't allow very long passwords or don't allow symbols within the password. Somewhat inaptly, Virgin Media only allow 10 character passwords without characters. :(
What happens when you need access to a site from another PC, phone etc that isn't running FF?
This situation seems to be happening more and more, can't people just leave other peoples stuff alone haha!
Everyone makes it easy for them, not patching systems and using weak/ outdated ciphers, is just as bad as users re-using non-complex passwords on different sites; they're all asking for trouble.
Can use password manager software. I keep all my passwords in a vault that's synced across Dropbox. The Dropbox itself has a ridiculous password and 2FA.
The password file itself is then secured using a 24 character password, which is less random, but still unique to me, and one I can remember pretty easily.
I have the app for the password manager on my iPhone, iPad, Macbook & PC, so I can access my passwords from anywhere if I need to, and it plugs in with most browsers and software.
probably spam accounts set up by bots
Sounds like the most likely reason - its possible with weak password systems that more than one string will match a common hashed password some of which will be random strings like those popular ones depending on how the passwords were reverse decrypted.
some sites generate a password for you when you request a password reset and they DONT force you to change it when you log back in, that could explain why some passwords are all the same if the site isn't generating a random password (or as random as people thought it was)
