MSI and ASUS Send VGA Review Samples with Higher Clocks than Retail Cards
Man of Honour
21 May 2012
Dalek flagship
http://www.techpowerup.com/223440/m...-samples-with-higher-clocks-than-retail-cards
Meh what does a few MHz matter lol.
It could be the difference between a lot of people buying one card over another. Many don't overclock, so just look at whatever card will give them more performance out of the box. A few extra fps on the benchmarks could be enough to tip the balance.
I know man that's why I was being a little sarcastic :D
"shocked to realize that this practice has been going on for years"
They've just noticed..........after years and numerous reviews! Poor reviewing in my view. Shows they don't fully understand the product they're reviewing.
Now we got VW thing going here.
In that case many of people that gotten the cards could return it as they have been TRICKED to what those cards run at out of the box !!!!
+1
If they can not get the basics right what value is the rest of the review.
I'm not sure how I feel, much like I had the same reaction when I got the letter from VW about my Golf being on their list of effected engines.
It's all down to what day to day problems it would cause, which in this case none for me, I could run the Gaming App and click one button, don't really feel cheated about that.
My opinion would be that setting review samples to OC mode as default just avoids the reviewers from missing the software or whatnot during testing. But you'd expect them to be told about it.
Exactly this, although the overclock is hardly much of one,
I bought a 4gb MSI 770 gaming from OCUK a few years ago and it was quoted as having clockspeeds that were only obtainable if you installed the gaming app, I reported it to staff but it was never corrected on the store page.
Looks to me more likely they sent a review board out at a certain clockspeed, then realised they can't actually get a good yield of boards that will do that speed, so knocked it down a touch for retail to speed bin a larger number of boards.
It's not like they sent them in with huge OC's.
Both of mine work at the review clock speed and above. To get the review clock speed you just press a button in the Gaming App.
I think they just advertised the maximum and then made it easier for the reviewers to get that maximum by removing the software element so no one forgot.
Considering they already send cherries (people used to care about this) it's kinda irrelevant.
Only honest reviews will be store-bought 3 months after release (when launch stock is replaced by crappier rev. B boards, cheaper coolers etc).
To be honest it's a non issue. You install the program, press the option and it runs at those speeds. Much like the advertised RGB feature on many cards requires the installation of a program, or to even get any performance out of a card you need to install the driver.
If required a BIOS flash it would be worth making some noise about as that is above what is expected of an end user.
