I'm looking for centre speaker upgrade suggestions for my current KEF 5.1 HTC3001se system.
It can't be bigger than the receiver for it to fit in the gap: 434mm x 339mm x 167mm
My budget is fairly open but I would only replace what I've got for something that's definitely an upgrade. Thank you
if it works ok stick with what you have, other wise with a set up like yours i would have just got a soundbar
