My windows 10 won't boot pass start up screen ( just spinning )
18 Oct 2002
Earth
Really hoping someone can save me here powers my system up ( just got home from work ) and the system is stuck on starting up and the little circle at the bottom just keeps spinning ?
Tried pressing F11 to start automatic recovery but that keeps spinning to .
Any ideas please not sure what else to try ?
Getting stressed as I have work I need access to .
Thank you
Try rebooting your PC about 3 times, during each reboot, you have to shut it down by holding the power button before it get's to the circle, then Windows may trigger the diagnostic screen asking for Safemode hopefully.
alternative is to get windows 10 iso burn to dvd or stick on a bootable usb and boot to that to get recovery mode.
Do a system restore to previous day it did boot as it sounds like its got stuck after a windows update.
Thanks that finally worked on about the 10th try system is all back up and runing now not sure what went on but pleased it's ok .
Thank you for your replies.
Cool
Not sure what software you use to backup. I would recommend Macrium Reflect to do a full backup to an external hard disk, on my system I have Macrium in the boot sequence so if the unthinkable happens I can restore a full recent PC backup in 15 mins.
Cool
Will look into Macrium Reflect do you use the home edtion or the free one ?
Thank you.
Thank you.
The home version, well worth the money. I setup my PC to do a full backup every 7 days. I had to use it once, I restored the full image from my internal hard disk to my 850 EVO SSD, took about 12 minutes.
