**NEW CORSAIR ML MAGNETIC LEVITATION FANS**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi Guys,
As most of you are aware Corsair are always looking at improving there range and making the performance and noise levels better for you guys.
Well they have managed to do both in the new range of fans. The New ML Pro fans have a High static pressure and high airflow due to the new design. The noise level has also been reduced which is a major plus side for most computer enthusiasts.
These changes to the fan cooling game mean they you do not have to choose better performance and lower noise level anymore as these have both.
The fans are available in both 120mm and 140mm.
We have stock landing next week so you can get your pre-orders in now to get some of the first batch.
Corsair ML120 Pro 120mm Premium Magnetic Levitation Fan @ £18.99 inc VAT https://www.overclockers.co.uk/cors...remium-magnetic-levitation-fan-fg-052-cs.html
Corsair ML120 PRO delivers unrivaled performance and silence by utilizing magnetic levitation technology and a custom rotor design.
The innovative design provides both high static pressure and high air flow, with an ultra-low friction magnetic bearing that simultaneously generates lower noise and provides higher performance.
A 2,000 RPM control range gives you total control between silence and absolute performance.
Replaceable corners mounted to anti-vibration rubber dampers allow you to match your fans with the rest of your build.
This no compromise fan also gives you full customization of both performance and appearance.
Features and Benefits:
- Magnetic Bearing: harnesses magnetic levitation technology to provide lower noise, higher performance, and a longer lifespan
- Custom Rotor Design: delivers the perfect balance between high static pressure and high airflow, operating flawlessly in the most challenging environments
- Extensive Control Range: A 2,000 RPM control range gives you total control between silence and absolute performance
- Color Customization: Replaceable corners mounted to anti-vibration rubber dampers allow you to match your fans with the rest of your build (Available separately in Red, White, and Blue)
Specification:
Box Contents
- Two - ML120, 120mm Premium Magnetic Levitation Fan
- Fan mounting screws
Performance Specs
-Dimensions: 120mm x 25mm
- Power Draw: .225A
- Connection Cable: 4-Pin
- Speed: 400 – 2,000 RPM
- Sound Level: 16 – 37 dBA
- Airflow: 12 – 75 CFM
- Static Pressure: 0.2 – 4.2 mm-H2O
- 5 Year Warranty
Only £18.99 inc VAT.
ORDER NOW
Corsair ML120 Pro LED Blue 120mm Premium Magnetic Levitation Fan @ £19.99 inc VAT https://www.overclockers.co.uk/cors...remium-magnetic-levitation-fan-fg-055-cs.html
Specification:
Box Contents
Performance Specs
- Power Draw: .225A
- 5 Year Warranty
Only £19.99 inc VAT.
ORDER NOW
Corsair ML120 Pro LED White 120mm Premium Magnetic Levitation Fan @ £19.99 inc VAT https://www.overclockers.co.uk/cors...remium-magnetic-levitation-fan-fg-053-cs.html
Specification:
Box Contents
Performance Specs
- Power Draw: .225A
- 5 Year Warranty
ORDER NOW
Corsair ML120 Pro LED Red 120mm Premium Magnetic Levitation Fan @ £16.99 inc VAT https://www.overclockers.co.uk/cors...remium-magnetic-levitation-fan-fg-054-cs.html
Specification:
Box Contents
Performance Specs
- Power Draw: .225A
- 5 Year Warranty
ORDER NOW
Corsair ML140 Pro 140mm Premium Magnetic Levitation Fan @ £19.99 inc VAT https://www.overclockers.co.uk/cors...remium-magnetic-levitation-fan-fg-057-cs.html
Corsair ML140 PRO delivers unrivaled performance and silence by utilizing magnetic levitation technology and a custom rotor design.
A 1,600 RPM control range gives you total control between silence and absolute performance.
- Extensive Control Range: A 1,600 RPM control range gives you total control between silence and absolute performance
Specification:
Box Contents
- ML140 PRO, 140mm Premium Magnetic Levitation Fan
Performance Specs
- Dimensions: 140mm x 25mm
- Power Draw: .25A
- Airflow: 20 – 97 CFM
- Static Pressure: 0.2 – 3.0 mm-H2O
- 5 Year Warranty
ORDER NOW
Corsair ML140 Pro LED Red 140mm Premium Magnetic Levitation Fan @ £21.95 inc VAT https://www.overclockers.co.uk/cors...remium-magnetic-levitation-fan-fg-059-cs.html
Specification:
Box Contents
Performance Specs
- Power Draw: .25A
- 5 Year Warranty
Only £21.95 inc VAT.
ORDER NOW
Corsair ML140 Pro LED White 140mm Premium Magnetic Levitation Fan @ £21.95 inc VAT https://www.overclockers.co.uk/cors...remium-magnetic-levitation-fan-fg-058-cs.html
Corsair ML140 PRO LED delivers unrivaled performance and silence by utilizing magnetic levitation technology and a custom rotor design.
- Radiating LED Lighting: Frosted translucent blades and four vivid LEDs for a striking look
Specification:
Box Contents
- ML140 PRO LED, 140mm Premium Magnetic Levitation Fan
Performance Specs
- Power Draw: .25A
- Warranty 5 Year
ORDER NOW
Corsair ML140 Pro LED Blue 140mm Premium Magnetic Levitation Fan @ £19.99 inc VAT https://www.overclockers.co.uk/cors...remium-magnetic-levitation-fan-fg-060-cs.html
Specification:
Box Contents
Performance Specs
- Power Draw: .25A
- Warranty 5 Year
ORDER NOW
View Our Entire Fan Range Here
Red, White and Blue models which cost more, the timing couldn't have been better; for 52% of the population anyway.
Seriously though it's about time this technology made it to fans.
Were the first batch bought before the pound took a dive by the way, i.e. are we likely to see the next batch cost more?
Hi,
They will be affected by the pound drop but I will honour any pre-orders made before the 8th July 10a.m. at the current price.
Are these better then the Noctua NF-A14 PWM Linus Tech Tips Edition?
Better in terms of what...?
Assuming quoted stats are all sufficiently accurate for a quick compare:
1500rpm, giving 82 CFM, or 2.08mm/H2O at 24dB for the Corsair
2000rpm, giving 97 CFM, or 3.00mm/H2O at 37dB for the Noctua
So the Noctua is not as high performance, but it's not as loud either.
The only special thing about the Linus edition is that it comes in Orange & Black...
If you watch a few video's on youtube a few have said their the quietest fans in the world.
At 37dB??!!
You're watching the wrong video's... MOST fans are quieter than this!!
The Furious Varder is only 12% louder on full chat, yet gets 51.6% higher performance on the StatPress side, for example.
ttaskmaster;29718473
At 37dB??!!
These fans can go much faster and be much quieter. I see the specs, but will wait for full review before jumping in.
At 37dB??!!
You swapped the brands there. First stats are for Noctua, second are for Corsair.
Maybe these are what I need for my 295x2! At present, under load the fan on the rad does get loud. So hopefully these bad boys can do the job really well! :) Might bag the blue 120s.
Think I'll order 2 of these tmoz. Need some lighting in my case and I think will do better than a light strip. Finding a place for the light strip is hardest part. These will add light where you can see them maybe?
Says who?
These are the Mfr's own specs and usually a bit exaggerated at that... If anything, they'll be slower and even louder.
Yes, you're absolutely right. Just debating whether to bother editing the post...
The point still stands, though - Noctua drop a bit in performance for a lot in noise. Still quite a reasonable compromise IMO, more so than the Quiet Editions.
