illuminated keyboard that works with Windows 10
1 Jul 2011
I have upgraded to windows 10 and I can't gey my Mad Catz Cyborg v,7 keyboard to be recognised, everything else on my pc is ok.
I have tried installing the drivers manually from the Windows/Temp folder but it still does not work, even though on the Mad Catz website I downloaded the drivers which are supposed to be Windows 10 compitable, I do not use the extra functions on it, but still cannot use it as a basic USB keyboard
Another cheap basic usb keyboard I have works fine
So it looks like I will have to get another illuminated backlit keyboard, can anyone recommend a make and model which does actually work with Windows 10
Thanks
Forgot to say cheapish keyboard
Thanks
Just in case anyone else is having the same problem with Windows 10 I Played around a bit more with device manager with this keyboard, in Device Manager it had 3 notifications, one unrecognised, so I told it to update drivers and for me to choose from a list, the cyborg keyboard was shown on the list but it did not work with this, so I tried again and instead of the keyboard I just chose USB device and it started working
