I had/have a Corsair AX760 which crapped out on me after about 6 months.
running an i5 2500k / GTX780 system.
It would not power on (unless i press and hold the power button for 10 seconds) to which then it would power on.
This unit was RMA'd and I received a new, sealed replacement. and that has been running fine for a while, but again after about 6 months it was being a little problematic.
Have just spent out a lot of money on a new system, X99, 5820k, 1080, 32Gb Ram etc, but decided to use the same power supply. the first few days, it ran like a dream, no issues at all, and now the same characteristics are back... if not worse, as my 1080 appears to glitch from time to time that is worrying me there is an issue with the card
in a nutshell, new build, the same fault occurs. the PC will not boot unless I press and hold the power.... can i assume, another faulty PSU?
I was under the impression the AX were corsairs near best of the best platinum grade, super warranty OEM Seasonic psu's - anyone else experiences similar issues? Should i get another one!?
