"Fixing" My AMD R9 290 With Pictures
8 Oct 2013
So iv been seeing my R9 290 drop into throttle hell over the last few weeks, doom dropped to a stutter (20fps) for 10 seconds at a time, throttled in the steam VR test to drop to 5.7 / 5.8. And worse of all to counter this until now I was pushing the fan passed 60% target speed and putting up with the jet engine noise of the 290's stock cooler.
So after seeing that the RX 480 would not give me anything extra at 1440p (I would maybe take a performance hit in some areas) I decided to strip the card down and check the cooler for dust build up and replace the thermal paste.
As I went through the process i found a few things that other sites miss / gloss over so thought id share my process, so here we go.
For starters here is the card in its normal case
u-IQOcQI5Xc7yAoq1NcDFeMz1fxE3cKaEjWBsMv26JU9Ki3xTLi4bQMayEoUXBjk79g7RHVaOw=w864-h648-no
1) Remove all 3 screws along the edge of the plastic cover, this will free the cover and allow it to slide off (i found that lifting it from the fan end first was the best way of this)
Now you can see any dust build up in the fan or within the fins above the copper cool plate / vapour chamber
gCZw7Hh43GmYnPURip6jIFVZFegC2InJvQpb3k3wXpamaFqSdgEC8auPCy5lYwOfqEJZy1Rgxg=w864-h648-no
2) Flip the card over and remove all 12 securing screws for the cooler and the 4 spring loaded screws around the GPU core (loosening these 4 best done slowly in a rotation 1,2,3,4,1,2,3,4 ect).
F0slWjsN96XHAhloYWj2hRd15kVqkh8AATSwEABn9SynORy2BVJAa8Nzm0m89R5T8AUxb8-zxg=w864-h648-no
3) Remove the 2 retaining screws on the IO panel
GeJzhZQrZ_DXywiweej9jpq6FH2lZRllX7OxbzUK6xQmFEovDI7Dtcgehr9FYbJv-Apxjcm-Og=w864-h648-no
4) Slowly twist the cooler until it separates from the card
yxMzPbsxn_E5lAE9hq-M3_iGNInnZhN8Z2uV1yat69ERzdDvlrcOXGNhRJW5WeJT8-e9XSFNFg=w864-h648-no
As you can see there is WAY too much thermal compound on the GPU itself
K-Wdy-v42FlwGTOseHd5HjCoaZuS8ZFpR0VEjaV3kUx9XEbU_9e1p1Ex60yiJEJD4r6KHxSfaw=w864-h648-no
5) clean up the fan and cooling fins if needed
6) Using isopropyl alcohol / heatsink cleaner clean up the GPU die and cooler contact, I also used a toothpick to carefully clean up the mass of old compound around the GPU die
7) re apply the new thermal compound to the GPU die (I used MX-4)
AGjhliiXHujkUY7NU7Nr4H8IXPTNiZwziyIZV5OtrggeEq4ZzChmZKUkpAg4K9HVsq9loMVS9g=w864-h648-no
8) I also put a small amount of the thermal compound on the VRM pads on the cooler, as these seemed quite brittle and where falling apart.
-VABRYXFtYzXqJ8bFOUTaErvC8NIGj-dwGLTL5Vp9h0TNMeGDF3z4BV10qnsxXZgSy4HHL4sZg=w864-h648-no
9) Now follow instructions 4 - 1 in reverse to put the card back together
After this I reverted my fan target to stock (47% i think) and ran the steam VR test, the GPU still gets up to the max temperature and throttles. But a LOT less often, my steam VR score on stock settings was 6.3 after the above process in comparison to 5.7 before :D
Something I should add is the original thermal compound was totally dry, after removing the heatsink the extra that was around the GPU fell off in chunks and flaked off of the top of the die itself.
Id image this type of thermal compound is very cheap and cheerful.
If you have an older card that seems to be underperforming this is well worth the effort IMO
Looks good, but why haven't you tried replacing the cooling on it? Even in a cramped space the reference cooler is pants.
Didn't want to spend money on the 290 with Vega around the corner. I normally skip a generation then get the 2nd best card.
And in all fairness the blower cooler is pretty good at pushing all the hot air out of the back of the case.
Im suprised they ever got these 290s to run on air cooling they run so hot :)
Are you running an overclock? If not you might wanna undervolt it a little, it might stop it throttling so often if its overheating causing it.
Humm no overclock, I'll look into undervolt thanks :-D
Cost about £50 to AIO cool my 290X and never goes over 60C
Seems like a lot of effort for little gain but if you like to tinker then fair enough
It's more the card is probably works £140 so I can't justify spending £50 on it. There was quite a gain really, doom doesn't crawl due to throttling anywhere near as bad as it was. And steam VR test has increased a fair bit for a 30 min work and some thermal paste
Surely those fans either side of the card are helping keep it cooler? Are they on a 5v for max speed?
Yep they do provide clean cool air to the GPU and overall the card with stock cooler works really well in that case. Still was throttling like crazy with the old thermal paste, now like I say it's not throttling anything like before.
Clean the rest of your case out, including the rads.
Will do at some point, this case has started to fall to bits tbh, some of the plastic has snapped. So looking at Corsair Air 240 to replace it at some point.
My main issue was GPU temps / throttle not CPU temps ;)
Yes but the case temp air flow is just as important...the more intake clean air the better the gpu will perform
So i would advise a total clean of the entire system
They don't gaming yesterday with a one to one fan profile my 290 pcs+ never even got above 60. Granted it was not a really taxing game in Resident Evil Zero remake. Even on Auto fan profile in the division it runs in the mid 60's. Any decent air cooler can tame the Hawaii gpu.
I had the MSI version of the 290 and found it had the wrong about of paste on. I had a load of issues trying to RMA it as it kepy over shutting my machine down as it turns out it was overheating. It wouldnt run anything over 1080p + 60hz. I repasted the gpu and refixed the fan and it worked well enough for a while on 1440p + 144hz but would get around 95 degrees playing CS.
Replaced it with a 1080 now but dislike the 290 due to the amount of problems i had with it.
