I personally never had an issue with the batteries myself.. I only use him and norb (links in the OP)..
Even thou it's safe to run batteries like LG Browns in 200 watt mods, as the mod will/should cut off before anything bad occurs, I tend not to as the battery charge will drain quicker and might not even last as long as a small mah battery at higher amps. Also I find the overall life cycle of the battery shorter.
It's like different engine cars.. Yeah your 1.1 litter might do 90 (around a track) but it might drink more fuel that a 3.2 doing 90mph.. And god knows what damage if could be doing to your engine.
Get batteries to match your mods power, or at least how you intend to use it..
