I cant see any on overclockers but a quick google has came up with a number of display port to hdmi cables. Would that suffice since the GPU appears to have 2 display ports.You're welcome.
You just need to check what type of inputs the monitors you decide on have too. For example, those Asus 1080p IPS I specced have 2 x HDMI and 1 x Analogue/VGA/D-Sub (same thing, different names) each. Unless you want to bother with adapters, the easiest thing would be to hook up your gaming monitor to the graphics card's single HDMI port and your other monitor to the motherboard's HDMI port, because that graphics card only brings 1 x HDMI.
Unless your intention is to use both for gaming, in which case you need a solution which allows you to run both monitors from the graphics card. Or different monitors with other type of ports. Or another graphics card with 2 x HDMI.
yeah say around the £50 mark, give or take a tenner.Budget being around £40 like the Antec GX500?
I've been told to look for something with decent cable management for decent air flow. And ideally i'd like something thats easy to clean, if it needs it?
