Hi all
Got the keys to our first home this morning all very exciting
The house needs a complete freshen up so there is a lot of decorating to do most of which I'll be tackling myself, maybe with a hand from my farther if I can persuade him!
When we viewed the house we noticed some strange patches in parts of the ceiling, they look like large holes have been drilled then filled in again afterwards, they are only upstairs.
In the corner of the room.
corner of another room
In the airing cupboard seems to be the worst of them.
The back ones are the worst with clearly water damage.
They seem dry now but i'll keep my eye on them for sure.
We viewed a few houses in the area and they all had them though I dont remember them having as many as ours does, or maybe they where just repaired better?
Ours have been re plastered but not painted.
The house has a flat roof so I was guessing they are left after repairs to the roof maybe? can any one shed some light on them?
Also most of the walls in the house are plaster board with wall paper that's been painted. A lot of the paper is lifting in the corners and on the seems.
Is it best to try and glue the paper back down then paper over the top of it with a heavy duty lining paper and then paint?
Or is it better to try and carefully remove the paper and paint straight onto the plaster board, filling any defects before painting?
I can see I'm going to be spending some time researching but all suggestions are welcome.
Before any of that I've a headache with a fitted stair lift that I have no idea how to get rid of?!
cheers.
cheers.
