Photoshop request: Logo For Vape?
Jeez, the OP asked for a logo, Im not a designer but I had a spare few minutes I fancied giving it a go. Sorry you and Acme have a problem with this.
Yes the text is stretched to 130% as I liked the look of it, you said I stretched it all which I did not.
Maybe some constructive feedback would be more helpfully.
I am being helpfully. I asked you why you stretched the text vertically. Being helpful isn't just telling you what you've done incorrectly, but asking you why you've done it so that you get used to thinking about the choices you make with regards to design.
You initially denied stretching it, which suggests you don't really want to learn, and those that aren't willing to learn usually don't progress very much at all.
Ok sorry I must have misinterpreted your post. I have removed the stretching from the lettering. I know the cloud is needs improving.
That looks better. I would increase the size of the font in corso so that it matches the width of clouds, but without stretching.
Just for a bit of context, product labeling and design is part of my job and is something I often do, and with that I've done a large amount of product labels for eliquids
