7 Jul 2016 at 08:34 #1 Minibiker Minibiker Soldato Joined 27 Mar 2016 Posts 7,619 Location Bristolian living in Swindon Hi all Looking for a couple of fans for the front and rear of my case... 120mm... Any reccomendations? Thanks
7 Jul 2016 at 09:15 #2 subbytna subbytna Soldato Joined 22 Oct 2008 Posts 11,768 Location Lisburn Haha, was just about to post the same thing. I'll await your responses too. Corsair AF look good but are expensive, hoping to get a recommendation for two fans that are sub £20 all in.
7 Jul 2016 at 09:21 #3 Artery Artery Associate Joined 6 Jun 2015 Posts 1,167 Location Nottingham Well it all depends if budget is an issue or not. Vardar F2 Gentle Typhoon Noctua
7 Jul 2016 at 09:56 #4 Minibiker Minibiker Soldato OP Joined 27 Mar 2016 Posts 7,619 Location Bristolian living in Swindon Budget no issue, was looking at Corsair with the colour rings on, look smart
7 Jul 2016 at 10:01 #5 Artery Artery Associate Joined 6 Jun 2015 Posts 1,167 Location Nottingham If budget isn't an issue then go for the Gentle Typhoon.
7 Jul 2016 at 10:46 #6 Minibiker Minibiker Soldato OP Joined 27 Mar 2016 Posts 7,619 Location Bristolian living in Swindon Artery said: If budget isn't an issue then go for the Gentle Typhoon. Click to expand... Thanks, they look very smart aswell
7 Jul 2016 at 13:49 #7 subbytna subbytna Soldato Joined 22 Oct 2008 Posts 11,768 Location Lisburn https://www.overclockers.co.uk/cors...irflow-dual-pack-co-9050002-ww-fg-003-cs.html are these good?
7 Jul 2016 at 17:42 #8 Smffy Smffy Soldato Joined 4 Dec 2015 Posts 3,358 Location London subbytna said: https://www.overclockers.co.uk/cors...irflow-dual-pack-co-9050002-ww-fg-003-cs.html are these good? Click to expand... I've got 7 of them in my build. Not too bad, they look good is why they make it to most builds but the airflow is decent.
7 Jul 2016 at 19:52 #9 Gimbal Gimbal Associate Joined 27 Jan 2016 Posts 97 Any suggestions for a 140mm? preferably with blue LED's? I cant be arsed with putting an LED strip inside the case, so the fans will do Thanks in advance!
7 Jul 2016 at 21:57 #10 Casterina Casterina Associate Joined 17 Nov 2011 Posts 852 Gimbal said: Any suggestions for a 140mm? preferably with blue LED's? I cant be arsed with putting an LED strip inside the case, so the fans will do Thanks in advance! Click to expand... My basket at Overclockers UK: 1 x Corsair Air Series AF140 1200RPM LED Blue Quiet Edition (CO-9050017-BLED)= £13.99 Total: £18.65 (includes shipping: £4.66)
