Right, after changing the oil a while back in my E46 330i and finding that some idiot has stripped the sump drain hole thread, I'm considering my options.
I could fit a self-tapping plug with a coarser pitch, removing oil the conventional way (this could go very, very wrong despite being mechanically competent). Or I could leave the plug in place and use a vacuum pump. These actually seem to get good reviews (well, the bad ones don't, obviously), so I'm thinking about buying one and never having to get oily under the car again. The plug is in properly, and seals fine. I'm thinking of leaving this sleeping dog to lie.
Anyone here got/used one? What is/was it like?
Any info much appreciated. Ta!
