Interesting debate...
Distance - miles
Weight - both stones and kg
Height - both foot/inches and cm
Temp - Centigrade
Bottle of gin - 1 litre!
Pizza - 12" pepperoni!
Indeed. A very British mess!
Distance - miles
Temp - Centigrade
Imperial measurements for engineering? *shudders*
SI is the global standard. No conversions, no long rows of zeroes, evolves to take advantage of increased accuracy and even the imperial system is now defined by SI units.
On another note, what is easier to work with?
6Oz butter or 150 Grams?
.Surely any claim as to whether they relate to practical quantities depends entirely on what you're used to / grew up with?
Your thou/mm argument is flawed since you deliberately used the 'nicer' number for the imperial side. 0.5mm is nicer than 19 and a bit thou.
))Which is a nicer number to work with
+/- 1 thou
Or +/- 0.025mm
Metric units do not generally relate to normal day to day practical quantities .
LITERALLY CANT WAIT FOR MILK TO NOT HAVE 1.13652L ON THE SIDE.
WHAT A TIME TO BE ALIVE
CAPS
http://i.imgur.com/j2NIfDS.gif
[FnG]magnolia;29766084 said:I found out via a pub quiz at the weekend that 1 mile does not equal 1600 metres as I'd always thought. It's actually 1609.something
How could I not be aware of this![]()
Have you looked at your tyres?
Tyres are seriously Metrinch.
(The wheel size, and therefore the inner dimensions of the tyre are imperial. it is only the outer parts that are metric.)
There have been repeated attempts to metricate tyres/wheels but they have always failed.
Oh look, another referendum thread.
Whoopdy ******* doo.
+/- a thou is actually a very good engineering tolerance (Possibly a bit on the tight side mind)
+/- 0.5mm and your pistons will be flying out of you wrecked engine block after a couple of dozen miles (Dozen! I have done it again!))
