980ti which sli bridge
10 Jan 2016
hi there guys, I currently have two 980ti's in SLI, using the standard flex bridge which came with my MB. I am wondering if one of those LED bridges would see any improvements (rather just in looks), or a HB bridge would do anything for my cards? one youtuber said the HB bridge could work on the 9-series, and even showed a FPS increase. Would there be any harm placing two bridges on a pair of 980ti's?
ps. do the 3-way bridges link both fingers?
many thanks.
For most things there is very little difference regardless of what bridges you use.
Sometimes one type is slightly better than another but it is swings and roundabouts.
Just use the one you like the best unless you are running some massive 8k resolution.
many thanks.
A 3 way bridge works fine in 2 way and gives you a space between the GPU's
hi there, thanks for replies. I guess adding a second bridge to an 980ti wont help anything? one guy on youtube showed it helped performance in the division? or at-least the HB bridged helped in one or two games? I dont have two flex bridges to try. I guess that 3-way bridge connects both fingers? thanks
