- 25 Sep 2012
- Scotland
I have a NZXT H440 case and have just purchased a NZXT Grid+ V2 digital fan speed controller. My goal is to get my computer as quiet as possible.
I am currently using the stock case fans with a Cryorig H5 Universal CPU cooler.
My CPU is a 2500K overclocked to 4Ghz and my GPU is an MSI 290X.
I thought I would do a little experiment to see how hot my CPU and GPU would run at idle with all fans turned off (except the 290X as the fans always spin).
I was expecting the CPU to overheat quite quickly what with the combined heat from the GPU and CPU being dumped into the case, but was surprised to see that the temperature stabilized at ~67 degrees C. Ambient temperature in the room is 23 degrees C.
Would you be comfortable with your CPU running this warm most of the time?
