Man of Honour
- 21 Nov 2004
Quite a lot of work for a puncture though
£430... Ouch!
What car..? What tyre size..?
Corroded disks are fine, they will naturally go rusty unless they are coated ones, and even then the friction surface will go rusty if you don't use the car for a while. You don't generally replace corroded disks. You replace warped or pitted/worn disks
£430? You aren't a woman by any chance are you?
[TW]Fox;29786753 said:430 quid for 2 tyres fitted, disks and pads fitted and alignment carried out sounds great![]()
about £100 labour to fit the disks and pads then...
They must have included the labour in the prices, because a set of front brake pads do not cost £70, and a pair of disks do not cost £130.
I'm fairly sure something with carbon ceramic discs or something fancy would cost more than that per disc..![]()
