I am looking to go with EK fittings for a PETG build, mostly because I know they will match the nickel on the CPU and GPU block (also both EK), and as far as I can tell they are considered very reliable.
I am planning on using EK-HD PETG Tube 1216mm, so I have identified the EK-HDC 16mm G1/4 as the correct fitting to use with this, which I assume is correct? However, as I am fairly new to this I am a bit puzzled what other fittings I will need? If I need 90 degree fittings (which I'm sure I will), the only one I can see is the EK-AF Angled. Is that correct? It doesn't say anything about it taking the 16/12mm PETG though. Any advice would be much appreciated, thanks.
