Best GPU 300-400 budget
10 Dec 2014
Hi guys,
I had a thread regarding this a few days ago and settled on https://www.overclockers.co.uk/sapp...rd-with-backplate-11247-03-40g-gx-377-sp.html
However spoken to ocuk to order today and they won't receive any stock until start of August and it's all sold. So I would be waiting even longer for the card to come into stock.
So I'll need to chose another card :(
The closer to the bottom end of my budget proffered but will go to 400 for the right one.
I'm using a 1080p freesync
The only futureproof that exists is selling the card soon before new gen arrives and buying one of those instead for a bit extra. Imo the 480x is a no-brainer if you have freesync, though with your budget you can get close to a 1070. Whether it's worth it to go for the 1070 over the 480x depends on how much you value your £ and how much you care about pushing the settings sliders to the max.
If my monitor wasn't freesync then I would be looking at nvidia more than amd ofc but from what everyone has said freesync makes a noticeable difference even if I achieve lower fps from the amd card it should look better due to the freesync.
I am unfamiliar with how that works to be honest and I have never seen the freesync to confirm that. However, if you can wait then surely a custom 480 is the way to go if you're going with AMD?
I still think a 980 Ti for 350 is the way to go
GTX 1070 is the better buy if you are paying full price right now as it performs better in DX12/Vulcan. Both great cards. Would also consider getting a Fury/Fury X/Nano (less than £300) and almost the same performance as the GTX 1070/GTX 980 Ti (especially in newer dx12 titles).
I think if you order the PowerColor Devil 480 you'll get it fast, I see everyone rushing to buy the Nitro instead, so don't think the queue for it will be that bad.
For under £400 the only choice 980ti.
Well I can think of one that is noticeably better than the 980ti!
And you know that too I suspect. Not only is the 1070 a faster card, be it at stock or oc but its noticeably faster in dx12 titles. This gap will only increase.
It uses a fraction of the power to achieve this and offers better dp support.
Unless you already have a 980ti and wish to sli or you can find one starting with £2xx then it's not a credible choice at under £400!
+1
I'm in the same price bracket but only really tempted by the 1070.
In the vein hope that prices will decrease, I'm biding my time but with great difficulty. :(
I purchased the Zotac 1070 amp edition last night (5p under your budget) and its apparently in stock. The 1070 seems to be a better choice in every way to the card you originally picked and it will compliment the rest of your setup very well.
https://www.overclockers.co.uk/zota...ddr5-pci-express-graphics-card-gx-103-zt.html
It's not really, Yes the 1070 is faster but as Digital foundry showed us with the Fury X v 1070 in Doom, When using Vulcan it has the Fury x well ahead by something like 25% meaning the Fury pro would edge a win too, Now while that's only one game and every other game today has the 1070 ahead having a 1080p freesync monitor and looking ahead the Fury will be great for a few years yet, especially with the adaptive sync advantage he loses by getting an Nvidia card with that monitor. So if he plans to stay on a 1080p freesync screen for a couple of years and wants a graphics card that will do a good job for a couple of years it's a good choice, It'd be better with more ram but it will be okay still. If not an 8gb 480 would also compliment the 1080p freesync panel very well and if I was buying today I would go with the 8gb option. If someone wants to spend there game time staring at an fps counter and going "Ooh this is ten frames faster than if I had the other card" then fine pay the extra for a 1070 but actually playing games without an on screen counter and you'll be hard pressed to tell the difference.
I am 100% wanting to stick with amd for the freesync monitor. I did want the fury but can't find stock.
Looks like I might just wait for an aftermarket rx480 as at 1080p this should be sufficient.
