Hi Folks.
I am planning on getting a new system built for me and would like some advice on the CPU as I am not really a pc tech guy.
The Display I use is the Acer Predator X34 (100hz 3440x1440) and the new PC will only be used for gaming.
So considering the spec and my required needs should I go with the 6900k or the 6850k ?
PC SPEC:
CASE: Corsair Obsidian 900D
MOBO: Asus ROG Rampage v Edition 10
CPU: Intel 6900k or 6850k (OVERCLOCKED)
CPU COOLER: Corsair Hydro h115i
RAM: 64GB (8x8GB) Corsair DDR4 Vengeance LED 2666mhz WHITE LED
GFX: SLI MSI Geforce gtx 1080 Seahawk X (AIO watercooled)
PSU: 1200w Corsair Digital AX1200i
SSD (OS): Samsung 256GB SM961 M.2 SSD
SSD: 1tb Samsung 850 Evo
OPTICAL DRIVE: Internal or External Blue-Ray & DVD (depends on case)
LIGHTS: NZXT Hue & RGB color changing dual channel internal led controller
OS: Windows 10
HEADPHONES - Sennheiser HD 800
DAC/AMP - Modi 2 and Magni 2
SPEAKERS - Razer Leviathan Soundbar
Thank you.
PC SPEC:
OS: Windows 10
Thank you.
(Not including any CPU)
