I've decided to go for a custom loop for the first time and as such i'm a bit lost in regards to actually choosing the parts. For budget reasons i'll only be cooling my CPU for now (see sig) and everything needs to be crammed in to my Phanteks Evolv case (see spoiler).
My basket at Overclockers UK:
Total: £258.46
(includes shipping: £10.50)
I've spec'd a 240mm rad for the simple reason that i already have two unused Noctua NF F12 120mm fans. I've no idea if XSPC rads are the ones to go for or if EK or someone else are better. I'm also wondering if i should go for a 360mm rad instead and then add another 360mm rad in the future when i add my graphics card to the loop.
I've put two blocks in the basket because they both look good but dont know which one performs better.
Since my case is a mid tower i've gona for a fairly compact pump/res combo.
I haven't specd any tubing or fittings or any other bits and bobs because frankly I dont really know what to go for. I've read in other thread that Barrow fittings are good quality and more affordable.
Any and all advice is much appreciated.
- 1 x XSPC EX240 120mm Radiator - Black= £34.99
- 1 x EK Water Blocks EK-XRES 140 Revo D5 PWM (incl. pump)= £106.99
- 1 x XSPC RayStorm CPU WaterBlock (Intel) V3= £49.99
- 1 x EK Water Blocks EK-Supremacy EVO - Acetal+Nickel= £55.99
Total: £258.46
