Oh yes... Sorry, I forgot that it was a US owned aircraft piloted by a US pilot and as such isn't allowed to do anything interesting at all.
As an aircraft, it's a terrible compromise. Trying to essentially replace almost every aircraft with a single model. Just like they tried in the 60's with the F111 - that went well...
The entire concept is a complete brainfart. The only V/STOL aircraft that has ever properly worked is the Harrier, and a big chunk of that is due to the Pegasus engine. And as for aircraft with separate lift engines to the the main engine, only 1 has been built in any numbers and that's the Yak-38, and that was retired 25 years ago.
The F35 has been designed around the engine and lift fan configuration, which isn't an economical design idea to start with and the airframe is shared across all variants, even the Air Force F35A's which won't have the lift fan. Add to that, due to it having to be a low observable aircraft, the weaponry needs to be carried internally. Normally that's along the centreline of the airframe, unfortunately, that's where the lift fan and associated systems are, so they're offset to the sides, which made it wider and heavier, and they've ended up with a heavy, bulky, slow, unmaneuverable aircraft that has poor visibility due to the bloody great big space for the fan behind the cockpit.
Sadly whats happened is they've ploughed so much money into the F35 project that it now has to succeed... Shame... it's only 7 years behind schedule and well over $160 billion over budget so far...
F117 took 30 months and 50 designers. That's what happens when you have a single purpose aircraft and leave the guys the hell alone to do their jobs.
Anyway...
The Eurofighter tried to put on a decent display. The cloud level wasn't helping all day really, very low level. It was certainly a noisy show, but just isn't interesting to begin with unless you like the politics of an utter shambles.
The A400M still stands out for me as the 'what the hell are they doing to that thing?!' moment.
