X99 Strix manual boot only or blackness
26 Jan 2010
hey guys, sorry its mr noob again
so on my new build i decided to go for a x99 strix mobo
All cool and built but since i built this system 3 days ago hitting the power button the PC always goes to a black screen,
it gives a single beep saying all is cool but unfortunately all i get is a black screen
looking on the bios I see that I have selected my SSD as boot drive one but it states its P2
P1 is my blu ray drive
The only way i can boot into windows is if i manually click on the ssd with windows installed, then within seconds it boots in and its ok
so im thinking is'nt the ssd with windows suppose to be P1 ?
i have 4 mechanical drives connected too, I have randomly connected the sata cables to random sata ports, if i disconnect all the drives apart from the ssd then it boots in ssd windows fine
I know its a setting issue as a manual boot in to the ssd is fine and ive been doing this for the past 3 days now
also going to advance bios mode shows ssd as boot drive priority 1but this listed as p2,
any thoughts?
just disconnected my blu ray and disabled every drive in the bios boot menu apart from the ssd, and changed the ssd sata cable to another port, still black screen, so had to select the ssd manually in the bios to boot into windows.
Sounds like you haven't set your OS drive as Boot Option 1 in Hard Drive BBS Priorities.
