The DVI-D cable that came with my HP LP3065 monitor is too short (1.5M) and I need a 3M one. But it shows artifacts on the screen with no sign of any proper signals being sent (can't see my desktop even the slightest).
The cable detects the monitor's name fine and isn't using the Generic PnP, so it seems to detect the monitor fine, but isn't streaming the content fine for some reason.
I have tried these two cables so far:
http://www.ebay.co.uk/itm/331463153113
http://www.ebay.co.uk/itm/252303640508
Both of which have the exact same result.
I also tested both cables on a different monitor (Acer XG270HU) which just shows the screen as black, and it goes from power saving to normal in a repeated sequence.
Any ideas what kind of cable I need to use to resolve this? As far as I'm aware the cable that came with the monitor is exactly the same as these ones I've bought and tested. I also tested the cable that came with my monitor with the Acer monitor which works fine too! So the issue is definitely with the cables I'm purchasing and not the monitors themselves.
Any help is much appreciated!
Thank you so much for reading!
