Is Maxwell's lack of hardware A-sync compute an issue if one were to buy an 980Ti to last last for the next couple of years?
Is it orth it? For gaming at 1440p
A valid concern, but from what benchmarks i've looked up an OC'd 980ti vs an OC'd GTX 1070 (which supposedly benefits from async) is only 5~ FPS behind in titles that make use of async. Whether or not that gap will widen with driver updates (i'm thinking it won't, even if so probably a negligable amount) remains to be seen.
Only other option is to wait for AMD's Vega but that's far away, and we have no tangible info on their performance yet.
For 1440p, yea, I'd say it's worth it.
Though you have a Freesync screen that can mitigate framedrops in many cases, I'm not sure which one you have. If you have one that doesn't even work below 48hz, I'd say you should still go for the 980Ti, as you are likely going to run into situations where games drop below 48fps on your 390 at 1440p and thus get no benefit from the tech.
However, if your monitor has a Freesync implementation goes down to 40hz or below, I'd say your 390 might still be fine so long as you aren't a stickler for high framerates. Freesync will smooth out an inconsistent framerate, but higher is still better and smoother and if performance is erratic enough, it will still feel bad.
