I'm looking to get the Three Fan Bundle of EK Vardar either F2 or F3 120mm to replace my heatsink and case fans as they are starting to fail with motor noise after 4 years of use however in the item description they are stated as "high static pressure cooling fan" so I'm wondering is it ideal to use them as case fans?
Also, the F2 (1450RPM) and F3 (1850RPM) bundles are the same price so if I get the F3 and use my motherboard BIOS to set them max at around 1500-1600RPM, they are the same as F2 but just different fan speed?
