I'd make sure they all have a smooth ramp so you don't hear any abrupt speed changes. Also set the fan speed of the exhaust fans to lag behind the intake fans to create positive pressure (for less dust in your case).
If you have any overclocks make sure the fans are at full speed before their point of failure too.
Thanks.
Interestingly the case fans don't seem to make a lot of difference. I set a flat case fan profile so they are steady at 600rpm, and only set the CPU fan to ramp up with temperature.
Ambient air temp in room - 26C
System temp - 38C with case fans at 40%
CPU idle temp - 31C with its fan on around 45%
During a stress test:
System temp - 38C with case fans unchanged
CPU temp - 58-63C with its fan ramping to around 70% (1350rpm)
So the system temp was unchanged.
I then repeated the test with the case fans at a steady 80% (around 1100rpm - marginally noisier but certainly not loud by my definition), and got exactly the same temperature results!
Not sure what this means. Extra airflow from case fans not making any difference. Maybe things will change once I get a GPU in there.
Also a strange thing I find - how can my CPU temp at idle be less than the system temperature? There should be nowhere for the CPU heat to go if the system temp is higher, and the two should equalise?
Edit - the fan speeds aint making a great deal of difference at all, so I think I'm just going to make them fairly quiet until temps hit 60C then ramp up to full speed. My system seems either to be at 30C at idle or above 50C when I'm doing something. Nothing in between, so there isn't a great deal of point in spending time tweaking fans in the 30C to 50C range.
