Mayhems X1 clear concentrate
22 Jul 2016
Hi I just bought some Mayhems X1 clear concentrate and it turned up today but the liquid inside it is yellow, the pictures online show its clear so I'm abit worried about putting it in my system.
Anyone here used this stuff?
I was going to use just distilled water and Mayhems biocide but Ek says on their site not to use biocide and also thought I would need a corrosion inhibitor because I have nickel plated blocks. I have never water cooled before so any help would be appreciated
Thanks
It says mix 100ml of Mayhems with 900ml of di water. I contacted Mayhems about it and they said to mix it with the water and see if it's still yellow once it's diluted. Just seems abit odd that it's meant to be clear but it's yellow. Once I finish my loop I will try it.
The yellow tint might be caused by the container and once you'll put it in a bowl to mix it with DI water you might realize it's in fact clear. Unless there's an issue with the coolant of course :)
I'm not sure about the X1, the XT-1 is yellowish by itself, but as soon as you mix it with water it does look clear.
But don't take from me, I'm colourblind :D
