- 24 May 2011
that is a great monitor indeed you can run 3600 x 2100 on that not just 2560 x 1440p. I've got an older TN Rog Swift and it's amazing still.
In terms of 4k there will be some newer gen monitors coming out, I would not recommend even considering any of the current 4k screens.
gtx 1080 is expensive but it has the power to run anything you throw at it and will be top notch for years. You can more than likely get away with a 1070 as well, if you fancy spending a bit less. I would not buy any card with 4gb right now, regardless of discounts.
You should be fine with a new and cheap 980 TI ( these dropped in price like crazy )/ 1070 / 1080.
But that is false the 1080 won't run anything you throw at it. The 1080 can't do Witcher 3 at 4k at a constant 60, which is why I recommend he waits.
