- 18 May 2010
- London
Wondering what I should do now.
I've been woking on getting my 3570k stable at 4.5Ghz... Long story short it has done stretches of around 30hrs of gaming then I will get a blue screen.
I am currently sitting on 1.33v in bios with LLC on extreme. Under Prime 95 it hits 90c. Gaming however it doesnt go beyound 70c.
When Prime 95 is running and load is at 100% vcore hits 1.356v high but I'm not too concerned as gaming temps dont go above 70c.
I've kind of been stubborn to lower the frequency to 4.4GHz as for the most part it is fine...
and my plan was to keep bumping the vcore 0.1 until it stabilises.
What do you reckon I should do. Keep increasing if I encounter more instability or just lower it to 4.4GHz as it will be easier to get stable?
and my plan was to keep bumping the vcore 0.1 until it stabilises.What do you reckon I should do. Keep increasing if I encounter more instability or just lower it to 4.4GHz as it will be easier to get stable?
but i settled at 4.6.
