Lian Li PC-O5SX, ITX Build
26 Aug 2009
Introduction
Style over function is what they said, not as nice as <insert other cheaper case here> they said... but I am happy :)
The initial build is nearly done and when it is I'll take some time to clean the case and take some photos.
I decided since it could have easily gone wrong I wanted to share my experience with it..
Why the build?
We're planning on building an extension, I will move from my study to the new larger lounge and my 'old' PC was just too big to be seen.
I had a Cooler Master HAF X Full Tower ATX Case, Asus Sabertooth X99, i7 5820k, 32GB Corsair Vengeance, Gigabyte Windforce 980Ti, Corsair 860 AX PSU - which are in varying degrees of being sold.
The only thing I kept from this PC for the new build were two 500gb SSDs and the AIO liquid cooler.
The Hardware
This is the case I used for the build, aluminum body and tempered glass front.
https://www.overclockers.co.uk/lian-li-pc-o5sx-mini-itx-chassis-black-ca-714-ll.html
and the final specification
  • Asus MAXIMUS VIII IMPACT Socket 1151
  • Intel Core I7-6700K Processor (4 GHz, 8 M Cache, LGA1151)
  • Cooler Master Nepton 240M AIO Liquid CPU Cooler
  • G.SKILL TridentZ Series F4-2800C14D-32GTZ 32GB DDR4 2800 MHz C 14 1.35 V Memory Kit
  • MSI NVIDIA GeForce GTX 1080 GAMING X 8GB GDDR5X Graphics Card
  • Corsair SF Series 600 Watt 80 PLUS Gold
  • SanDisk Ultra II SSD 480 GB Sata III 2.5-inch Internal SSD up to 550 MB/s
  • Crucial SSD ~500 GB
I am waiting stock of the GTX 1080, and will continue to use my 980ti until it's sold - unfortunately this is likely to happen before the GTX 1080 is in stock!
Early Progress
These photos were before cabling, excuse finger prints
13724056_10157451868285227_1679506423909966690_o by dancook1982, on Flickr
13708233_10157451868685227_6945230669988523065_o by dancook1982, on Flickr
13731037_10157451868295227_4891900596413588432_o by dancook1982, on Flickr
13723894_10157451868275227_3008923791102195850_o by dancook1982, on Flickr
13698297_10157451868650227_1934844382491960786_o by dancook1982, on Flickr
Cabling
13767321_10157454118985227_2288534067790863093_o by dancook1982, on Flickr
Issues
I was concerned with this build, will the graphics card fit, what about the cooler, what about air flow??
Graphics Card
My 980ti is 11inches long, as you can see from the image it fits, there is another ~1 1/2inch space.
The case is reviewed as taking smaller length cards, however this is because of a drive rack which can actually be easily removed to give it the space.
PSU
The Power cable which runs internally through the case is pushed up tight against a rod in the case. Fortunately it is not a show stopper, tight it may be, it fits.
240mm Radiator
I was concerned about space for the 240mm radiator, fortunately as I already had one in my old PC I had nothing to lose by trying it. I found it was actually fortunate the positioning of the PSU cable because it would have been in the way of the fans, I would be concerned about other PSU options with this Cooler Master Nepton 240M.
I did have to remount the radiator later on because of another issue....
RAM Space + CPU Cooler Block
Because of the tubes coming from the CPU cooler block it was tight up against the RAM, I had ordered the G-Skill, which are thicker than the Corsair Vengeance I was using temporarily and they did not fit. I almost sent them back for a refund when I had the idea to mount the cooler upside down..
Fortunately it worked and the cables did not impede the fans. I could have turned the fans round to put the power cables at the back, but when I realised I did not want to take it apart again...
13615021_10157475848110227_8637051116630709253_n by dancook1982, on Flickr
Not Final Images
I have a couple of images of the build on my desk, with the Corsair RAM, I will however do some new ones properly and clean the cables up when I get the GTX 1080.
13719474_10157455855660227_8379946984457369157_o by dancook1982, on Flickr
13692779_10157455855650227_8185678054679990467_o by dancook1982, on Flickr
Overclocking
I easily overclocked the CPU to 4.7ghz just changing the multipliers, it's stable and I haven't tried going higher yet...
Final Photo
I have cancelled my GTX 1080 order, I will keep the 980ti for a while longer, I only bought it in december 2015 and it does a fine job.
New PC Build by dancook1982, on Flickr
maybe I should get some LEDS, as when it's dark all I can see is an upside down Cooler Master logo..
New GPU
Pascal Titan X
Watercooling
I've ordered..
EK-FC Titan X Pascal - Nickel
EK Water Blocks EK-XRES 100 DDC 3.2 PWM Elite (incl. pump)
EK-Cable Pump testing adapter
Koolance Radiator, 2x120mm 30-FPI Copper
2 x Noctua NF-F12 IndustrialPPC 3000RPM PWM 120mm High Performance Fan
EK Water Blocks EK-FB ASUS M8I Monoblock - Nickel
Mayhems Ultra Pure H2O 5Ltr
Mayhems Fine Silver Kill Coil
9 x EK Water Blocks EK-ACF Fitting 10/16mm - Nickel
3m Primochill Primoflex Advanced Tubing 16/10 - Clear
Rockit 88 - Black Body - Black
Coollaboratory Liquid Ultra Thermal Paste
But I must most looking forward to some Haribo...please OCUK... please..
I see you've ordered a Rockit 88, fancy renting it to a fellow Lian Li owner for a few days? :D
I thought about buying one, but international shipping is stupidly expensive for a 1 time use item.
